pulling hair out over fast idle!!!!!!
can any one help???
my manual TT is running at 2000rpm, ive cleaned the IAA and regulator valves, TB's and replaced all pipes around the IAA, the TBS is set to .045v and all connectors have been cleaned i.e water temp, AAC and FICD and the regulator connector, but it still runs high. that is untill i disconnect the AAC valve connector, then it drops. please is there any one out there that can help???
Well I aint no expert but Id have a look at trouble faulting the AAC
remember if tyou have cleaned throttle bodies and other components,it will take a couple hundred miles for the ECU to learn the new readings etc
have you ajusted the base idle,using the ajuster screw in the side of the IAA unit?although thats a high rpm,that would take a lot of ajustment to bring it down,does the rpm not settle even when warm, if you have problems with the IAA unit
Idle Air Regulator (IAR).IAA This valve lives on the the intake manifold, above the passenger-side Its temperature sensitive open when cold, closed when hot. That makes the car idle higher when it's warming up,cleaning of the yellow and blue connectors at the back of the iaa unit may help
ive set the base idle to 700rpm with the AAC conector off but it still jumps up again when reconnected. all connectors have been cleaned. i guess i will have to wait a couple of hundred miles to see what happens
your only up the road from z tech,welcome to pop over for a 2nd opinion based in baydon berkshire
im booked in on the 3rd, was just trying to sort out the dam probblem myself, had my manual conversion done there, bloody fine chaps are the ztech boys. i think il leave it for them
shhh greg this is between me and you yeah....
baydon is in wiltshire :x:
I had this happen to me this weekend when i set the base idle and adjusted the tps........then I read one post that says to disconnect the tps ( grey plug that u connect the multimeter to) for at least 10 secs with the engie running ,then reconnect it to clear the tps section of the ecu self learn and that sorted it out.
well disconnecting and reconnecting the TPS has brought the revs down, but now as soon as i bring the engine up to 2000rpm it drops to around 1000 and bounces up and down continusly, i think im gona have to leave it for the ztech boys. thanks to every one any way that gave me advice on the mater. cheers guys
Dont give up yet mate
The idle air control sys is quite simple if it is that.
The jumping rpm sounds like a stuck air adjustment control valve as the exact same symptoms happened with a audi I had once .Take off the pipe to the valve and try to get some wd40 into it and try again after letting it soak for a bit.
