anyone know why my car might struggle at 5000plus revs in every gear???
lower down seems ok now!
Membership No 0780
INSURANCE GOOFA
  • Replies 74
  • Views 1.8k
In all honesty i dont know as i hadn't fixed the air leak before the bov's were fitted and it was then struggling all the time but in all honesty i hadn't noticed it as bad before they were fitted
Sounds like the BOV's could be contributing to this, try to refit them, but really as I said before get it on a Boost leak tester/conzult.
old/faulty or wrongly gapped spark plugs can also cause weird problem at higher revs, but normally it only occurs under boost.
Might be worthwhile to check anyway.
They have been replaced already mate.
Membership No 0780
INSURANCE GOOFA
I have just been given a lend of a boost leak check :dance:
And i am waiting for the datascan to come, only ordered it last night though.
Im starting to think it could be the BOV's, but noone else seems to have any problems with them.
Membership No 0780
INSURANCE GOOFA
well my det sensor is bypassed mate.
and no error codes.
and its uk spec so shouldn't have a limiter should it?
ok im thinking of bypassing my det sensor, do you get any additional problems with the car or is it okay?
this may be a stupid question but what is a datascan thing, an how much do they cost
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=8041109585&ssPageName=MERC_VIC_ReBay_Pr3_PcY_BIN_IT
Alot of people will say you shouldn't really do it as the det sensor is there for a reason which i do agree with ,
however with me spending so much it was pretty much my only option.
hope this helps mate
Membership No 0780
INSURANCE GOOFA
just read all the thread, this is what i personally would be doing now...
replace bovs with stock UNTIL probs are sorted, trying to mod an engine with a problem is like trying to ice a turd, pointless and a waste of good icing.. (no disrespect meant here bird)
check plugs again and make sure gaps are spot on, also i ONLY use NGK, the best there is my a mile...
get injectors professionally cleaned out, and replace ALL dodgy connectors...
check coil packs and do what u can with them, look for leaks, cracks and general condition...
sounds to me like one of 2 things, either the spark is weak or the fuel isnt getting thru...
take off all mods u've done til u get the problems sorted out mate, if ur not confident doing all this get a pro to do it for you, and give it a good going over, usually a well recommended garage can sort this sorta thing out pretty quickly...
hope this helps, and hope u get sorted..
T
p.s. why have you binned the det sensor, surely this is unwise??
T
Non taken mate.
I have checked the plugs and they are fine.
checked the coil packs and everything too.
i definately need the connectors so that could be causing a problem, may not be fueling correctly but i am getting about the right mileage though.
The only mods are the BOV's and Air filter.
General condition seems to be quite good, cant see any leeks but ill double check for that.
It might be an idea to take off the BOV's and see if it is hem or not.
Membership No 0780
INSURANCE GOOFA
MATCHES.jpg[/img]
Sorry mate only kidding :x:
But jeezus your car is scaring me
MATCHES.jpg[/img]
Thats been on my mind too. maybe i should break her instead of trying to fix her
Membership No 0780
INSURANCE GOOFA
NOOOOOOOOOOOOOOOOOOOOOOOOOO
Just get it plugged in
I will but you can see why im thinking about it, i must have had almost every possible problem with the car
Membership No 0780
INSURANCE GOOFA
have u got a stock ECU on the car mate?? also does the car go normally upto 5k revs?? as in was u would expect performance wise??
have u tried a different fuel pump??
T
T
i havent tried a different one no, in all honesty im not too sure how quick it should get there but is a lot better than it was!
The ECU is the stock one mate yes.
Membership No 0780
INSURANCE GOOFA
i think xav2075 had a prob similar to this
turned out to be a shagged o2 sensor (so the import company said)
this would REALLY piss me off m8, i feel for ya
stick with it though
im trying but ive kind of put so much in to it now its just becoming annoying.
i should have the datascan in the morning though . . . apparently
so that will bring up things like the O2 sensor.
Just got to hope it works :rolleyes:
Ive already spent alot of money as my sig says but thats just what i can remember, its probably more but only a little bit i think
Membership No 0780
INSURANCE GOOFA
chin up m8ty
just think come summer time u will be glad u did, roof and cruising!!
chin up m8ty
yeah if its not still broke lol
Membership No 0780
INSURANCE GOOFA
O2 sensors can cause stuttering at 5000 revs but the root cause on mine was traced down to a leaky intercooler. If there is an air leak in any part of the turbo systems - piping, intercooler etc it can cause hesitation and stuttering of engine response. A conzult test looking at the Mass Air Flow Sensor graph results should indicate an air leak if there are abrupt spikes.
I reset my O2 sensor learning every week with my Conzult. Seems to keep the engine smooth, but i could be imagining it!
How much are O2 sensors??
I just hope it nothing too serious really.
im just sick of spending money on fixing it now! :mad:
Membership No 0780
INSURANCE GOOFA
About £60 each i think but you have to be sure that its those rather than an air leak in the turbo systems
oh of course, just wondering now so im not shocked lol
Membership No 0780
INSURANCE GOOFA
YOUR WORDS (Oh, i forgot to tell you that we found one of the big problems!
You know the 4 big turbo pipe thingies, well one of them wasn't on properly so most likely thats why it was sometimes cutting out and also a big leak)
You did fix the above problem?
yes, just put it back on correctly
Membership No 0780
INSURANCE GOOFA
