rear light are done......
Did my rear lights today, the 99 spec look........
NEVER EVER AGAIN....... !!!!!!!!
bloody messy, my fingers are hurting, my overalls are ruined....!!!!!
but worth it......
from this......
to this..... :dance:
thank fook its finished....
APACHE - once again thanks very much.....
Andy....
It's not the 99 spec look, but it does look a million times better than before. Nice one. :)
looks gud mate!!
i just done mine a few days ago,
bloody messy job, hands, clothes, that black stuff gets everywhere.
What an improvement!
Much better ... well done mate
Looks soooo much better.
Looks nice, but you should have put some thin black pin-stripes in there as well :D
BTW, someones nicked your number plate ;)
ok ok, its not quite the 99 spec look but it near enough and loads better than those crap light covers.........
i'm pleased with them....
thanks guys...
Andy...
I think they look great. the wheels are excellent too.. :) :cool: :D
very nice looks like im next if only someone could do a fotoshop for me to see how it would look :-).................
Nice one Andy - great job to do isn't it............yuuuk
Did you use the silver tape at all???
Must get off my ar5e and get mine fitted as well.
yes mate used the tape, once again i thank you for the stuff you sent.....
horrible job, but worth it......
cheers mate
Andy...
Hows this mate?
wicked - BUT FOR GOD SAKE, GET RID OF THAT FOG LIGHT !!!!!!!!!
do the rear light conversion, its a piece of p**s to do, you can get the rear inner brake lights wired up as fogs.......
search the forum for how to do it.... here you go.....
http://www.300zx.co.uk/forums/showthread.php?s=&threadid=16572&highlight=brake+wiring
cheers
Andy..
i've done another little mod today on the rear fogs.......( I bought the car with the INNER brake lights converted to fogs )
I like the rear brake light set up when BOTH the inner and OUTER brake lights come on, but with the INNER fog light conversion only the OUTER brake lights work......
As I NEVER drive the car in the winter or the rain ( unless i'm caught out of course ) I have fitted a rocker switch in the boot of the car which means I can change between BOTH brake lights working and NO FOGS, OR just outer brake lights and inner fogs as when I bought the car...
So for MOT's ( and the unforseen bad visibility days ) I can flick the switch in the boot so that the fogs work, and for all other times the switch will be set so that the both brake lights come on......
NOTE : I still have a switch inside the car on the dash for the rear fogs for when the boot switch is in "rear fog mode" for the MOT etc.
does all that make sense ???
Andy..
......I have fitted a rocker switch in the boot of the car which means I can change between BOTH brake lights working and NO FOGS, OR just outer brake lights and inner fogs as when I bought the car...
I like that idea.
:confused:
silver tape, to line the inside of the rear lights to give a better "glow" to the rear lights through the clear lens......
the standard lights are just sprayed white inside the lens housing, the reflective silver tape help distribute the light better...... ok.
