February 20, 200620 yr I have got a new steering wheel and a HICAS boss for my ZX TT... I'm a bit of a novice and was wondering if there was one of those guides on how to remove the wheel and fit the boss and steering wheel... is it an easy job? Z Man
February 20, 200620 yr do a search mate 'removing steering wheel' .. loads of threads on this .. HTH Chris
February 21, 200620 yr there is a screw behind the bottom spoke of the steering wheel ( dashboard side ) undo this ...take off horn push pad , taking care to remove connector for horn switch / cruise if you have it .....undo the big nut on the top of the steering column holding the wheel on , the next bit is the hard bit .....geting the wheel off the shaft where it has lived for up to 16 years on some cars ....the best bet is to make a steering wheel puller basically a bloody big bolt in a threaded block with two more bolts , one through either end of the block ...cant remember the size now , but i think they are around 6 or 8 mm , these locate in two tapped holes in te steering wheel and as you tighten the big centre bolt against th esteering column the two small bolts pull the wheel off for you ...there may be easier ways im sure the forum will tell you if there is but that worked for me .. good luck steve
is it an easy job?
Z Man
