dump valve question
mine seen to be starting to dump around 5000revs and the when i do put my foot on the clutch its just a little swish noise, is that right, also seems to be holding back around this time
Membership No 0780
INSURANCE GOOFA
  • Replies 26
  • Views 657
also nothing to do with the clutch its when you lift off the throttle
I also wouldnt be taking it to 5k if its not running properly
adjust it! It should dump when you lift foot of accelerator at boost pressure above 0...more audable above 2-3 psi
Just remove them! Return your car to standard and get it running 100% before you do anything else. :)
From what I've read it wasn't running all that well originally.
but i shouldn't here it start going ssssshhhhhh while im still accelarating at all then?
Membership No 0780
INSURANCE GOOFA
no, im thinking of buying a datascan
Membership No 0780
INSURANCE GOOFA
definatly not...springs to weak..it cant hold the boost pressure. There is usully an adjuster which tensions the spring.
Erh? What's that got to do with the price of fish? I said it's better to return the car to standard and then get it running correctly before you start adding things to it. It wasn't running well to begin with was it.
b****r beaten to it
eh, i dont know what you mean
Membership No 0780
INSURANCE GOOFA
No it wasn't but people seem to think i should get it on the consult test so ill buy a datascan and put it on there instead
Membership No 0780
INSURANCE GOOFA
Datscan won't fix it. It'll just show you what's not quite working. If you return it to standard, then it'll be easier to see what's running right and what's not. You start adding other bits to the equation and it'll just take more time.
thats all i want to know, whats not right at the moment
Membership No 0780
INSURANCE GOOFA
It's not going to tell you what's faulty with anything you've added to the car though.
so stop wasting money and take it to the local nissan garage an get a ****ing conzult check done see what ****ed an go from there :mad: :rant:
rant over
rant over
Thats what im saying, will the datascan not give me pretty much the same answers as a consult?
Membership No 0780
INSURANCE GOOFA
yes, and it is a worthwhile purchase. However just like conzult, it is not the answer to everything.
thats ok, but everyone is saying i need to get it on a consult but when i see the price difference i could buy a datascan for the price nissan would want just to look :headvswal
Thats why i mentioned that.
Anyway, as for the BOV's, seems like i need to turn the spring then so it holds the boost, is that right :wack:
Membership No 0780
INSURANCE GOOFA
Lee,
Turn the nut on the top of the bov till it is 2-3mm past the thread, any more than that and you will get stalling and dumping problems (ohh weeer) if you need any help give us a bell :)
Lee,
I think that must be the problem, i think they were just turned all the way to the loudest
Membership No 0780
INSURANCE GOOFA
That doesn't adjust the pitch, that's done by the red circle on the side, smallest hole loudest, biggest quieter.
The bolt you need to adjust adjusts when the bov will dump.
OK, i will try to get it sorted tonight then.
Membership No 0780
INSURANCE GOOFA
That was fun reading that thread that made just as much sence walking into the living room where wife watching sad tv this upsets me to watch /our remote dont work/get up then turn it over you div?
i dont get it lol
Membership No 0780
INSURANCE GOOFA
