Advice needed on what type of glue!
Hi Guys
I need to glue some plastics together for some mods on my Zed and i dont have no idea on what type of glue to use
The glue has to be able to withstand high temperatures and be as strong as fvck but also be of a clear nature so that its not really visible!
Please dont come back and say superglue as that stuff is crap
Can anyone help
Fas
it all depends on what plastic you are trying to glue?? to which adhesive you want to use have you tried modelling glue poly cement ect. that might work.
Modeling glue (polystyrene cement) is ok for ABS plastics. But it makes the section to which it melts a little brittle.
Yes what plastic do you want to glue fas? Then I can tell you what to try;)
i dont wanna say but i dont think iv got a choice
Basically i wanna glue together some angel eye light units to the plastic inner light piece in the headlights
Has to be able to withstand the heat from the lights and not be really that visible and also be really strong as the car has stiff suspension and will be vibrating like fvck
Heres a quick piccy of the mess LOL
Fas
a lil job like that, araldite rapid will be more than up for it! :cool:
Is it clear in colour and how strong is it, i just dont wanna have to take my lights apart if it doesint hold!
Fas
I used epoxy two part glue , araldite or similar, when i modded mine to take mercedes HID,s , i cut out the zed bulb holder and glued in the merc one , these must get really hot but i,ve not had a problem with them and its nearly clear :dance: :dance: HTH
Araldite offer a range of epoxy (two part) glues. Decent shops have the whole range and they should say what colour, temp resistance on the packaging.
I've used 2 part epoxy on my rear light conversion and it worked a treat. Can send you some if you want as it comes in 5ml sachets.
Thanks for the offer Phil, just wanna make sure that i get the correct kind as i want a glue thats gonna handle alot of heat as the Light units will sit right in front of the headlight bulb so will be very hot
What exact type is it if you dont mind me asking?
Fas
When I was going to do this before I realised what a big fookin PITA it would be I was advised by Cos to use a clear silicone sealent, as this what Cos used on all his conversions. HTH
Ill look it up mate
Fas
Fas
Will send you some details tomorrow as I don't have it at home ;)
Cheers Mate
Fas
