code 34
im getting code 34 det sensor circuit or something from a conzult check, how does this effect my cars performance?
  • Replies 27
  • Views 1k
well if it resets each time the engine starts why is this necessary? :confused:
like i said, what i did worked, reset the code and got it out of safety boost,it wouldnt reset no matter how many times i stopped and started or turned on and off the ignition.
the way i think it works is: the code is found, and is kept as a fault, and then to identify how long ago the code occurred, it tells you it happened 'XX' starts ago.
if it reset each time then it would always happen "1" start ago and would never change.
since i cured my fault it kept it as a fault. and the start counter would be the only thing changing. until i entered diag mode and came out of it
Fraser
To be honest mate im not all that sure, just what i was told.
I need to know what my rattle is as its really bad :(
Membership No 0780
INSURANCE GOOFA
Just my 2p worth.
I think the code 34 indicates a "failed" det sensor. In this case it can never pick up det, so assumes det will occur and the car always runs in safety mode.
The ECU will also set the car in safety mode if the car registers det through a functioning det sensor. In this case it retains safety mode until the ignition is turned off and turned back on again. It then runs normal until (or if) it detects Det again.
There is a difference between the two......
CheerZ
StuartR
