RAZO Pedels
Just got some nice RAZO Pedels off EBAY with all the fitments etc, does any one know where I can down load a set of insturctions to put all the clips on the back of them as they don't have to be drilled into the original pedels on the Z like most after market ones, the just slide over apperently??? :confused:
Thanks, Jon ;)
I had RAZO pedals on my car before I sold them to Hellraiser. He'll know. I just removed them, didn't fit them, so I'm not too sure.
really easy to do
loosen all the bolts to max
hold the pedal firmly onto the rubber of the pedal to be fitted to.
with other hand slide each of the two sring bars either side of the pedal rubber.
slide the top bar down to cover the two spring bars
tighten the top bolts first then the bottom ones to firm up the razo onto the original pedal.
repeat twice more and you are done
hth
gaz
Thanks Soooo Much everyone for your help, didn't have a clue on this one with the brackets!!! :D Thanks for the scans Dave as well!!! Brilliant!!! :bow:
