Hi Guys can anyone help me?
I have just fitted a Racelogic Traction Control Digital Adjuster and the car wont go over 2000 rpm without missfireing.
On the original adjuster it was working great,the problem only started when i fitted the new one.
Does anyone have the correct settings to wriye into my laptop please?
Steve. :confused:
Steve. :confused:
The settings should be held in your RLTC ECU Steve so not sure why this would happen. :confused:
Download the sw (if you've not already got it) from http://www.racelogic.co.uk/_downloads/traction/Traction_MKII.zip
I have attached my current settings file (note, rename the file so the extension is .TRA) The only change you may need to make is the wheel sizes and positions as this varies from car to car.
Give me a buzz if you need any more help (07977 431401)
Steve :)
'93 UK TT Manual
sorry to hijack, but are you still using the settings from my DAT file i made steve??
No Paul - I just used it as a reference for my wheel sensor settings and they turned out to be different anyway :D Any reason bud?
Steve :)
'93 UK TT Manual
Steve :)
just wondered what settings you were using & how they compared to mine :)
Ahh gotcha! Thanks again for the DAT file bud :bow:
Steve :)
'93 UK TT Manual
Steve, let us know how you got on with this last night. Hope you got it running bud..
Steve :)
'93 UK TT Manual
Hiya Steve ive still got the same problem allthough at least it works when its switched off,so i dont think it is the digi adjuster now.
Steve, check your Rev Limit settings. Soft cut should be 7100rpm and hard cut should be 7200rpm. After seeing your wheel size settings, it's possible that these are wrong as well..
Steve :)
'93 UK TT Manual
