Just spent all week fitting stuff to my Z, started her last night and was fine, went out today to tidy things up, and she wont start!! the fuel pump isn't coming on, i have checked the fuse and its fine... any ideas??
ok been out again, when i turn the key the fuel pump "clicks" but does not run!
come on teckie people.. someone must know!
Dude have you checked small fuse box near boost senser box or fuel pump relay in drivers footwell.
ahhh... in the drivers foot well? i was playing with the one behind the pas seat! but the pump is still clicking, what does it look like and where is it?
Its a pain to get to. Drivers footwell, tucked in behind the accelerator pedal. You will find its all in Japanese too. ;)
But there aint a fuel pump fuse down there :D
mate you need to take off plastic panel,which holds fuse cover 2/3 screws behind gas pedal and 1/2 kickplate once cover is off you will see fuel relay green/yellow in colour.
I will have a look at the relay in a min, i can normaly hear the pump prime when i go to start her, but its no longer doing that.
So its most likely to be relay or fuel ECU?
Thanks for the help and links guys
been out..... again! shorted out the fuel pump control unit and nothing, checked the fuse and its fine, the relay is clicking, so im coming to a somewhat depresing conclusion that my pump is fooked! :cry: :cry: :cry:
havent got any bloody money for a new one as iv spent all my cash on the mods iv just fitted :headvswal
is there any other tests i can do or am i just going to have to save for a pump?
why is it cars always go tits just beffore christmas :headvswal :(
Worth checking your alarm+immob if they arm/disarm properly.
haven't got one mate! does anyone know where the power leads are for the pump? i can always hook up a 12v bulb to se if it lights up when the pump should come on
Take out the spare bud,there's a srewed down panel, remove that and you should see a plate with wires and fuel hoses attached.
if you remove that, the sender/pump assy all comes out together.
Follow the leads off the pump and check like you said-do it away from the open tank tho'!! ;)
If your pump is dead I have one but JUST the pump!-i.e it needs soldering to the mounting plate!-but it's deffo good!! :D
is this the same for a SWB mate?
Ah!-got me there mate!-fuel tank could be under rear seat?-procedure should be the same tho'!-Give Chunk a pm bud-he's a shorty man(no pun intended!) ;)
:hyper: :hyper: :hyper: :hyper: fixed it!!!!!!!!!! :hyper: :hyper: :hyper: tried shorting out the other wire on the control unit.. and she works!!!
Cheers veryone for your help.... this forum is mint!
now just need a new control unit!
