Smoky after stood??
Car been stood for around 6 months now apart from a couple of trips to the bodyshop
Started it up today to drop the oil for the winter.
Car was smoking like fook (it smoked a tiny bit before) now its 10 times worse.
Will it be o.k. after a good run?
getting a little worried now.........
A bit peed off because I found out I havent done my light conversion properly (works fine when engine not running), coolant temp gauge dont work anymore, this n that and I have a slow puncture :wack:
Valve stem oil seals. Since it's been stood for ages, it might be ok after a good drive.
white smoke??? condensation in the exhaust.. mine smokes a little after a good rain but goes after 2mins max..
Mines the same, if its cold or raining when i fire her up first thing she smokes a bit but once she's warmed up its fine. One thing thats bugging me though, when its been running for a good while, if im stuck in traffic or stopped at lights now and again i get smoke coming up past the drivers side window - baring in mind this is the side the exhaust runs up coz its single exit, any ideas?????
does it smell oily
could be a spot of oil dropping on to the hot exhuast coming up from underneath the car,or as said just condensation-remeber now winter is here its like when we breath in the cold weather the vapour shows up,its no differant than hot fumes exiting an exhaust in to the cold
Cheers lads.
needed a second opinion was getting a little worried
