Does anyone know what the difference between R32/33/34 front brake disks are. Also what size is the R33/34 disk 330mm x ?????
Vijay
Hi Vijay sorry can not help you with your question however was in a breakers Tuesday and they have a (1994ish) Nissan Skyline in there, almost unrecognisable (fire damage) no wheels and sitting shoved into the mud was the disc and caliper.Hmm bit of quick removal I thought but the whole suspension leg and caliper missing the other side...
dammit. oh well
Jeff TT
I think the R32/33 fit under the standard 300 wheels but the R34's are to big. Sorry I don't know the actual sizes.
Standard R33 discs are 320mm diameter and need larger rims with enough offset for clearing R33 caliper. From memory, R32 calipers will fit inside standard wheel but need either spacer or grinding down the logo on the caliper to clear.
-Andrew
Checked mine - they are 324mm by 30mm. 320mm came off a spec I had for R33's. Must be variations in size used I guess?
-Andrew
