high idle
car idled fine for the first ten minutes after it warmed up but then switched off and on and it wont go under a very steady 1200rpm. what should i check?
Ya5een mine was doing that when the weather was very hot now its cool not been happening again i wonder too.
min e has started doing this, but ive had the battery on and off all weekend doing my welding, seems to have calmed down now though
ย
hth
If you had the battery off for a bit, I know Yas has been doing a bit of work so you may done as well, then you reset the ECU, mine always runs a bit high for a while after its been reset, soon settles down once you have done a couple of runs and its learnt a bit. I would explain it better but gotta go out, that the basics tho.
gotcha, thanks richard
