Shims
Last time I had my brake pads replaced, the numpty that replaced them didn't put the shims back on and kindly left me with a pile of metal plates in a box.
As I am replacing brakes this weekend need to put the shims in this time.
Please could you advise what I need and don't need. I have (picture attached):
4 metal plates with grilles cut into
4 metal plates in a wedge shape
8 smaller plates which were together in pairs
2 small corners
Also where do these go when I fit them...
Rob
am I missing anything I need
Not quite sure what the x2 are but all the others look fine. Small ones will be for the rear.
look like the pad retainers on the diagram - only have 2 though... are these needed??
Thanks for all your help with this... Probably take me all weekend to do the brakes...
Anything I need to do to prepare pads and discs when I take them out of the box and fit, I'm sure the pads go on as they are but do I need to clean the discs with anything..
usually have an anti-rust coating mate, just give em' a wipe mith brake cleaner.
Just had a good look at the shims and in places the coating has come off, slight rusting - is this an issue.. Will this make a difference if I bought a new set? Also how much is a new set and who will have some in stock?? I have put them in WD40 for the time being.
Cheers Mantav8 - Can I pick up brake cleaner from somewhere like Halfords??
Thanks Again
Bump
Thanks Again
I actually thought mine were stainless but now I'm not certain. Mine are pretty knackered, but it never seemed to make any difference to the working or installing. They should have a fine coating of copper grease anyway.
Brake cleaner is available in Halfords. As far as I can tell from the smell it's spray cellulose thinnners, so that or meths would probably work fine too.
Thanks Andy.
Do I coat all sides of the shims??
Rob
rob if you need someone to fit and replace all of your brake parts i would be willing to ofer my services to you as i am a mechanic and have just done all the brakes on my car
Carb cleaner that leaves no residue or isopropyl alcohol ought to be fine too.
A bit of surface rust ought be no issue on the shims, as long as they're still in one piece, just give them a clean, light coating of copper grease and you're away.
If you need a new set, though, I think I have a set of fronts and rears in the shed (boxed and new) that you could have for postage + a few beer tokens.
Stupid question from me....
When I fit my Brembos I take it I wont need to re-fit these shims as the pads are different sizes....are they only needed for the standard nissan brakes? will i get new shims with the new bigger pads or are they not required at all in the Brembos? :slap:
Yes the new pads will be a different size.
I think my new calipers have the shims included (as well as the pads!:D).
Suggest you call Mike Feeney to check in his catalogue for what you actually need.
Yeah, likewise,what Andy said. Shims are in mine to. I don't think its a major bother if you don't fit them, just desirable. Don't they help stop squeal and general noise? I expect someone on the skyline forum has some knocking around they can throw your way, or Mike. Dave
