Currently changing Air Filter need advice from some who has done it. Please
Just taken my stock filter box out to fit apexi, but I am not sure what to do with the splash guard that is now only fixed at the front and is therefore a bit loose. Also the plastic intakes at each side which went into the stock airbox are a bit loose, what did people do with these bits?
leave the plsah guard in as it stops rain getting into the air filter, the other two pipes you can leave , you have to undo them from insuide the wing/bumper and wiggle them out
Did mine at JAE (with some help) didnt remove anything else other than the stock filter everythings fine :dance:
Sorted, I put cable ties around the T hoses and air intakes to keep them solid and made two brackets to hold the back of the splash guard.
So everything that is left is now secure.
Was not sure if I should put a bracket on the new apexi, it seems solid as it is so have just left it attached without a bracket.
