Hi guys, i'm in the process of replacing the two pipes connected to the metal pipe that holds both temp senders. I obviously need to re-seal the metal pipe to the block and was wonderin if anyone had ideas on a decent gasket sealant to use??
Rich :rolleyes:
Is there not a gasket for it? Can't remember!! If so you wont need any sealent.
[sIGPIC][/sIGPIC]
Cheers chris, you've done this job recently aint you? There is a genuine nissan sealant but apparently it costs a bomb. I'll take a trip to halfrauds once I get the new pipes to see what they can rip me off with!!!!
Rich
Spoke to Mr F before - No gaskets mate just sealant.
i used 'hermetite' instant gasket from halfrauds, worked fine!
Just use a silicon based ''instant gasket'' mate-worked fine on mine! :D
Same here.
No Probs.
use blue instant gasket
dont use red instant gasket its watery and **** :xxx:
Blue it is then!!!! Cheers fellow Zed'rs
