- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
God Dam, Just about finished the Engine pull work, altho the dam engine is still in the car and the Tranny has 4 bolts left in the bell housing( and yes that includes the F*#cking top 2 :o(() had to knock off then to get back home in time. Everything else is sorted ,going back to finsih it off in a weeks time.
The General Topic here is : GOD DAM what a shitty job "Proffesional" Mechanics do to your car these days.
I am as most people are here somewhat paranoid about taking my car anywhere, so generally only take it too the most reputable places i can find. However looking at the tranny work that i recently had done i was APPAULED at the totall over all lack of quality. Here is just a short list of things that pissed me off :
Reverse indicator wire severed at trannsmission and Tied in a Knot around the Speed sensor wire !
Center Support Bearing - U joint Coupling Screws hopelessly over torqued or locktight fitted or something as i had over 700 lb/ft of torque on em and they still would move(nissan recommend 78MAX i think) , had to saw the CSB off and Super heat the screws to get them off in the end.
Tranny Bell housing bolts again hopeless over torqued in places and hand tight in others. One of them has sheared meaning a nice day of drilling and tapping ahead of me somewhere.
Driveshaft Heat shield secured with only 2.5 out of 6 bolts,
Shifter bracket bolt Welded very poorly on.
Sheared Exhaust bolts had been replaced with equally old and woefully under strength bolts .
That isn't even mentioning the state of the Spark plug and injector connectors. and even the oil filter was hideously over torqued.
So instead of just simply swapping turbos and Changing the odd component i think im goin to have to replace a large ammount of hardware /wiring and connectors also. which is a general pain in the ass, i think from now on i will only ever use "professional's" if im so severly short of time i can't do the job myself. which is often however i would sooner be without my car for a while than have it butchered in such a manner.
In short peep's think twice before you take your cars to places that aren't gonna take the care they should do of them.
I might take the time to point out that altho i dont allways trust nissan, as a whole the Jobs i have had done by them all seem to have been finished pretty well, dont take this as gossple tho!
Z ya
Nico91TT
