April 7, 200521 yr hi changing plugs soon any tips on how to do it without damgeing the engine :xxx: had a look at the engine today and it looks like rear one are under a bar type thingee do i have to remove that bar? please help thanks :bow:
April 7, 200521 yr hi changing plugs soon any tips on how to do it without damgeing the engine :xxx: had a look at the engine today and it looks like rear one are under a bar type thingee do i have to remove that bar? please help thanks :bow: yes you will have to remove the balance bar to get to cylinders 5 and 6 , basically its just a case of removing the coil packs then plugs and replacing with new ones , be careful with the connectors as they will be brittle and don't lose the O rings on the balance bar other than that its easy Ryan
