Wiring in my Apexi gauges....
All
I need to wire in my water temp gauge and my oil pressure gauge. Now, the water temp gauge seems pretty straight forward but I am guessing that I am better off removing the Gauge Temp sender unit from the water pipe and plumbing this into the top rad hoe pipe that has the posssiblility of connecting a sender unit? I think I have heard that you get a better temp readin from here....
In regards to the Oil pressure unit, I havent got a scooby what that goes to? Any aides anyone? Wheresthe best place on a Zed to measure the Oil pressure?
TIA :)
Oil pressure sender info here
Still not got mine sorted :rolleyes:
Steve :)
'93 UK TT Manual
hi mark i used smithy hardpipe and got him to weld in ther sender much more reliable readings IMO :cool:
Mark it's not so much the location of the stock sender that is naff on the zed, it's more the actual stock gauge it self. Am putting my apexi water temp sender in place of the stock one on the top inlet pipe in next couple of weeks, you can if you wish also use the same stock wiring and just dis-connect behind interior pods and connect your apexi wires there, if you wanted too, seen a few of the Aussie guys do it that way.
smithy
Hi Guys
Smithy I think I will wire the Water temp unit into the existing loom....
As per other post, I need an oil pressure sender unit.....I diddnt get one with my apexi unit.....its an electrical unit so how does it work? I need a unit t measure the pressure and then send the result to the guage.....rather than the guage reasing the pressure? Does that make any sense at all?? :D
