Serious missfire after 2500rpm!
:confused: car is running like a pig! will run under 2500 rpm
above that is like its running on 2 pots.
I think its vacuum fault but not shure, as its when
the turbos are coming in as if no petrol?
any ideas would be helpful
thanks in advance
allan
PTU imo ,
do you have a spare to swop it out with ?? they can be repaired at home but its not too easy , try doing a search on the FAQ or tech advice about the repair method
Steve
yep, certainly sounds like the AFM as a faulty AFM will not let you rev past 2.5k.
Vijay
dirty connections on the air flow meter, pull off the connector and clean them all up and then refit, do a ecu reset and all should be fine !!!
Checked out today and is ....................
AFM fault. Replaced unit and all is well
Thanks for help :) :)
