Evening All
Just a quickie, where is the best place to plumb in the boost signal line for my Profec B? Preferably on the left side somewhere as that's where it's going through the bulkhead. Also, is it ok to 'T' off this hose inside the car for a boost gauge? I figured a leak anywhere in these lines would be bad news as far as controlling the boost goes, so I want to keep the number of junctions to a minimum in the pipes. Is this good 'boost housekeeping'? :)
The best place to tee it into is the line to the original boost sensor on the RHS of the engine bay.
You can tee into the line for the fuel pressure reg, but I wouldn't recommend this as if it comes off you'll lean out.
