hardwireing a road angel
hi, can anyone tell me the easiest(and safest) way to hardwire a road angel in a Z32, as im starting to get a bit fed up of all the wires all over the dash any info will be apreciated. cheers
I used the switched live to the stereo for wiring in my speed trap stuff, so it comes on automatically when the car is started and I cant forget to turn it off and end up with a flat battery. I think the fuse is 15amp for this which should be more than enough to run your tunes as well as the road angel. those that are into oopper dooper sound systems will probably say this is bad for the sound quality or something but i've got a fairly basic system and it doesnt seem to harm it... im a bit mutton anyway :D
Ive Got A Road Angel But It Wont Work In My Car ???
It Dosent Seem To Want To Pick Up Any Signal?? Where Have You Put Your In The Car.
It Works Fine In My Van Every Day But When Its In My Car It Shows
---mph Insted Of 000mph
Any Ideas
i've got the bluei which has a separate antenna which sits in the corner of the windscreen in front of the steering wheel, never had any probs, does the angel have a built in antenna?
Any Ideas
do you mean won't work in the Z? if so should'nt be a problem
ive had both the old and new road angels in a Z and both work,
if you mean another car, then it could be it has a heated front screen
and in that case will need a special adaptor, try (if you can get it to reach)
temporary against the back window, but in ZX no reason why it shouldn't work on the front screen, or sit it on the roof until it picks up a signal
then move it to the drivers window, then gradually move it to the position you want it
as for hardwiring it, tidiest way is to run the wires under the dash (two screws above the speedo etc) then it can be very easily wired to wherever you want
To raise a valid point, Is'nt it illegal to use a road angel, I know its not illegal to own one, but is'nt it illegal to use?? Therfore, hardwiring it into your car proves your using it, and the law would love that!!
I may be getting confused with radar jammers??
no m8 perfectly legal
as you say laser jammer is;)
It's not illegal to receive, ie detector, just illegal to transmit to avoid prosecution, jammer.
Simon.
the missus has just done this bit of her course at police academy, jammers illegal, GPS doo-dads fine, some forces even encourage them and the radar detectors are a bit of a grey area and apparently there are moves afoot to ban em...
not that that will stop me using any of them! :D
I read in artical in the newspaper the other day saying that some motor companies are going to be fitting them as standard!
