I'm a finn living in Germany and I like to drive fast.....
I just bought a european model 300ZX Twin Turbo automatic yearmodel 1991 with low 99 tkm........ to tease Porsches.... BUT:
I have been trying to reach top speed in several occasions, but it gains max 240 km/h...usually only 220-230... (that I can do with my VW turbodiesel too...) secondly 0-100km/h times (hand timing up to 105km/h in speedometer scale) it goes in 7,6-8,0 sec...isn't that too slow too??
The engine sounds really excellent, idle around 850-900, no odd sounds, only injectors faint knocking, no shaking.... it sounds almoust like V8....
The automatic gearbox is also working well, changing the fourt speed at around 200 km/h in full gas acceration (rps around 6500)
There is absolutely no leaks...except little hissing sound from right exhaust manifold (or somewear near) after turning off hot engine (like some water would be poured on hot turbo kind of sound)
The turbo pressure goes up to around 0,58 bars and motor heat is in good range all the time (little bit below middle area at +4-10 C outside temperature)
Could it be possible that one cylinder would be out of order...can the engine really sound so good in that case????? In that case what would be the most likely broken part.....ignition or injector?
Any hints, ideas check ups would be greatly appreciated!!!
By the way...will 100 watt H3 lamps broke my reflector lights? The 55 w were giving as much light a a bad flash light....
Hello!
