- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
After having my Zed sprayed about year ago I finally got around to doing something about the tired grey trims on it. There had been some slight overspray on some of the grey trim that goes up the windscreen and along the targa roof panels. Also the strip that goes between the targa roof was starting to blister and look a bit tired. I had been thinking over the last few weeks how best to sort this problem out. I did not want to go to the hassel of spraying them and going over them with back to black (silicon spray) just did not last long enough. What to do....
I thought that an easy way out would be to use self adhesive black vinyl ( like they use for car stickers). So this weekend I bought a metre of this material and set to work. I cleaned all the trims with panel cleaner to remove any old silicon spray so the vinyl would stick. Measured how wide each strip would need to be to wrap around the trims and started to apply the vinyl. I did have to rub down the strip between the targa panels because when this stuff sticks it does show any bits of shit that may be under it.
I simply applied the vinyl, smoothed it out and wrapped the edges. Cut each end with a very sharp stanley knife and then used the key tool required, a hairdryer!!. The heat from the hair dryer helps the vinyl to shrink around the angles the trim goes off at. It also helps the the adhesive bond better. The result, a Zed with trims that are high gloss black and look brand new. Take it from me it makes it look like a different car. I had all of this done in just under 3 hours (including fag breaks!!). Making sure the surface well prepared and smooth will ensure you get a good finish. I also did the trim that runs along the top of the doors just to finish the job. This is one easy job anyone could do to improve the look of their car. Have a go......
Seez ya!!
Simon H
