Syphoning petrol
My car sits on my drive awaiting the verdict of guilty ( written off and taken away ) or not ( Written off but I can keep it).
It has done precisely thirteen miles since I filled it up, and I don't want to let that disappear with my car. Anyone any idea how I can syphon this off, as there seems to be anti-syphon baffles in the filler hose to stop this. I've tried diverting a hose in the engine bay as the fuel system is pressurised, but it only gives me a spit and then stops. I'm unable to turn the engine over as my collision has pierced the oil coolers.
Any suggestions welcome,
Simon.
remove spare wheel, remove square plate, remove pump assembly, there you go :)
Why thank you kind sir. Now to get my toolkit and straw out.
Simon. :duffer:
I had the same problem in my NA, I am not going to tell you how I did it, cos I was a very naughty boy ;)
You bad boy! :nono: :D
Jack car up, hammer screw driver through bottom of fuel tank, place Large container underneath!! Job done!
I did similiar, but used a very low speed drill. Only on the basis that it was too slow to cause a spark and the fuel would dissipate any heat caused, and the tank was full to the brim, so not enough air in there to ignite. :slap:
More difficult to control the flow though! :D :D
Ask your local Chav or scrote...they'll know
