T.p.s.sensor
I Recently Installed A New T.p.s On My Imported Tt. Using A Digital Voltmeter Reading Between .45 And .47 And Various Settings Inbetween I Have Been Unsuccessful In Getting The Car To Change Gear Without Revving It .any Help Would Be Much Appreciated
fully closed (at idle 750 =/- 50) bet 0.4 /0.5
2000 rpm 4v ish
Hope that helps bud.
If The Problem Still Persists Should I Reduce The Voltage Readings ?
Can you give a more detailed description of the actual problem ?
What made you decide to replace the sensor ?
"it won't change gear without revving"
Sounds more like a gearbox problem..
Did you do a AT ECU selfdiagnosis ? what were the errors ?
-Eric
I Think That The Voltage Reading Is Too High. I Am Going To Set The Reading At About .43 .it Is Currently Set At .46 .am I Right In Assuming That The Lower The Voltage The Lower The Revs Required To Change Gear? I Dont Know How To Do Ecu Analysis. The Gearbox Was Completely Rebuilt (new Looms Etc ) A Year Ago.the Oil Is In Perfect Condition. The Bottom Bolt Is Missing Off The T.p.s. Would This Affect The Setting? I Used A Digital Voltmeter To Set Up The T.p.s. I Set It Up Once At About .46 And The Car Was Aceptable For A Few Days . I Did Not Use The Car Fort Three Days But When I Drove It It Seemed To Revert Back To Over Revving. What Is The E.c.u Thinking? Thank You For Your Help
