J Spec Fogs on a UK car?
Having had my 99 Spec front fitted, I have finally got hold of some J Spec front fog lights with integral side lights. Currently the front fog positions are filled with the UK spec side light/indicator combo which are still working. Does anyone know if the 99 spec indicators have integral side lights (I had assumed they did) and are therefore compatible with the UK connector? I assume that I will need to split the sidelight switched live to the Jap fogs sidelight connector when I wire in the new switch for 'em from the cabin?
Have not explained this very well, so hope you understand what I'm getting at :rolleyes:
CheerZ for any help!
Steve :)
'93 UK TT Manual
nope, the 99 spec indicators are indicators only
you need to modify the wiring to the lamps (indicator & side light) & wire an additional feed for the fog lamp :)
Many thanks Paul - you've saved me some ground work bud!
The fog lamps have three electical feeds - am assuming ground, and switched live for each lamp. Should I bother about a fuse for the fog lamps?
CheerZ
Steve :)
'93 UK TT Manual
CheerZ
Steve :)
yes mate, & run it through a relay too ;)
CheerZ
Steve :)
Easiest way is to buy a fog light wiring kit from Halfords - Ring make one, costs about £10.
It contains all the wiring, fuse and relay. The switch is pants but you can buy a nice one that blends in with the dash elsewhere.
Richard :cool:
Many thanks fellas. Will pop down to Harry's and take a look..
Steve :)
'93 UK TT Manual
Ill expect a call then shall I???
lol - I'm trying to do stuff myself ;)
'93 UK TT Manual
Ill expect a call after you've broke it then? lol
lol - I'll be in touch bud ;)
Steve :)
'93 UK TT Manual
