October 22, 200124 yr Hi guys, When fitting an upgrade air take that eliminates the hole std box, what do I do with the sensor wires to stop it going into safty mode? A diagram of the loop out or reconnections would be pukka. cheers harve
October 22, 200124 yr Erm.. Aerm... You don't eliminate any sensors when replacing the airbox... The MAF (thing attached to the airbox with the wire coming out of the right hand side) stays.. Assuming you want your car to run, that is.. Az ------------------ Stage: Rather Ill
Hi guys,
would be pukka.
cheers harve
