In memory of Mandy
My fuel pressure is too high!
Hi,
Did a test with John Dixon today and my Fuel pressure is 0.1 bar over what is should be at idle and 5 bar peak!
Is there any other reason my fuel pressure is up apart from a fubar'd FPR?
*could* also be a blockage/restriction in the return line. you could disconnect the return & test it with a hose into a can. more than likely the FPR tho
Silly suggestion time - when my FPR was.. erm.. on backwards.. I was seeing pretty much the same pressures as you - 75psi at WOT..
Is your fuel hose setup stock, or did you move your FPR like I did?
Bloody el he is back how ya doing Aaron? FPR setup is stock BTW!
Will have to find someone to swap FPR's and check the FP then!
