Best contact cleaner?
Just went round all the coil packs, injector connector connectors and PTU and found the usual green corrosion. Wacked a load of halfords contact cleaner over them, and it just wont shift it. Have scraped some of it off with a small screwdriver.
Anyone reccommend a good contact cleaner that will actually dissolve this green crap?
Also when I put all the connectors back, it runs worse. Have been round twice and re-seated and checked everything and still the same. ECU check code 55 all OK, so may re-set it and see if that helps.
Have you tried carburettor/choke cleaner? May have to
leave it a few minutes as it will dissolve the corrosion
on the connectors, i used it on mine. Worked a treat!
See you tuesday Al?
Sounds like a good plan. Yea will see ya Tues, no more working lates for me from next week, start me new position working 8 till 4 most days :D
try a bit o brake fluid (a smidge corrosive) that should help...dont need a lot as it is quite aggressive to say the least,,
cool- thats 2 votes for carb cleaner- will get some at lunch. Handy my new office- got a dodgy car parts shop one side an halfords next door the other side :)
What about electrical conductivity???? Or will it vapourise??
could be a worry. Guess I should do it at the weekend just in case. Once the crap has gone, should be able to blast away any leftover carb cleaner with the solvent based contact cleaner
if you have a maplines they actualy sell an electrical contact cleaner that desolves copper oxidisation.
Says exactly that on the can and works fantastic.
ok, I have a Maplins round the back of Slough Trad Est so might be worth a look in. Cheers!
Fish and chip van here I come. Baggins says Vinegar will do the trick.
There- got me 500 he he :hyper:
