Adjustable camber arms
Can anyone tell me if these are available here in the uk ?
Front and rear ?
Also HICAS eliminators ?
Mark
If you've a TT then the rears have an adjustment. Its a cam bolt on the inner pivot on the top link. Easiest way on the fronts is shim plates on the inner top link mounts.
I'm sure there's also people here will be able to get the fully adjustables s
You can always get them from Stillen in US
Mark I ordered parts from Courtesy Nissan USA, once they got their act together with UPS Post parts were here quite quick, also it might be quite a bit cheaper getting parts from USA with the weak dollar, there are adjustable links shown on the link I am posting here.
http://www.courtesyparts.com/z32/index.html
HTH cheers John Crisp
Harve does a camber adjustment kit for the front, but this is to correct it, you can change it with the various pates that he gives you with the kit to whatever you need.
AFAIK you dont need to do the back? its only the fronts that go on lowering??
You could eliminate the hicas by removing the sensor on the back of the wheel, but that is a bodge job so wouldnt personaly do it. Best to buy a propper kit.
