hi... i am wondering if i can fit the cheaper piston type dumpvalves (the kind that you would find rs turbo/cosworth owners fitting to there cars) that cost around 70 pound each, or do i have to fit jap/american type blow off valves that cost about 200 pound each?... if i can fit the cheaper type dv's does anyone know what additional things i will need...
you can fit the bailey twin piston dump valves no problem (i have them), but you will have to make your own adapters/piping
I used to have the bailey ones as well stuey0604 has them now and they worked ok but i now have the apexi bovs and there much better but i have the fitting pipes with the plumbing in if you want them
Kirbz
Hey there bud, sorry to be off topic, but where in West Sussex are ya? as i live round that way sometimes. :tongue:
They have different ratings too??
Some Baileys twin piston are rated at
and some are above 12>psi
Which one to go for as Std boost is 7-9 psi but boost controller pushes 15psi.
Will it damage anything getting the >12 psi one when running std boost? as it will not open up all the way and vent and possibly bounce back into the turbo?
hi.. i live in the worthing area, just along the coast from brighton.
:dance: Yay :dance: I'm normaly in Chichester area! so not too far
