Help Turbos Not Working?
hi my cars been stood for one and half year it starts fine but i think turbos arent working need some help come on guys :cry: :cry: :cry:
what makes you thinkthey are not working? does your boost gauge move?
no scoops its not moving thats why i thought they arent working so m i right then?
But how does the car feel - if your turbos aren't working you WILL know about it
And you should be able to hear it go off boost very definitely, even without BOVs...
Gauge connector might be borked after standing for so long - might be all your problem is! :cool:
Or maybe he meant the -car- isn't moving :rofl:
BTW I'd get some fresh fuel in it soonest!
So far we have deduced that something isn't moving and it hasn't moved for 18 months.
This has to be the vaguest post we've ever had.
Next question:
Are the wheels turning? Yes/No
Next question:
Glad its not just me that thought this.. class lmao
whos moving
where they going?
steve
whos moving
where they going?
steve
were are u moving to bud :p
well the car moves and yes wheels are turning its just boost gauge thats not moving as u can see above in scoops post. the car starts ok but it only gose to 2500rpm and come on guys i didnt ask for jokes i need some serious advice thank you
zevans the gauge connector is ok and fuel i will put some in you could b right there thanks
If its only reving to 2500rpm it sounds like the MAF, try cleaning the connectors.
Yep MAS is goosed....
If you're going to ask a question you need to be a bit more specific!
Saying your turbo's aren't working then a vague post about no it's not moving is about as much use as a chocolate fireguard.
It sounded like the car wouldn't move or something.
If you'r turbo's weren't working it would be running rough, stalling etc.
Try taking your Z to a Nissan dealer and saying "it's not moving" and see what funny looks you get.
If it's only going to 2500rpm it will be the MAF (air meter sensor) under the panel between the headlights that's either gone faulty or has bad connections.
Chris.
and yes the fuel goes off over time so that will make it rough.
Aye bet -those- connectors have rotted. Now if Ibran had mentioned the rev limit in the first place... :rolleyes:
Ibran, there's a writeup SOMEWHERE that tells you how to get to the connector etc but I can't find it with a quick search... have a look yourself for MAF and/or AFM...
check your air filters, might be totaly clogged up and the maf could be holding back the revs , is it ticking over OK no rough idle , will it rev with the clutch dipped ?
steve
steve
The ecu puts a 2500rpm limit on as a saftey mode if theres an electrical fault with the MAS ;)
thanks guys MAF are these same in uk and jap imports cos my car is uk model and i changed the MAF with one out off an imported car could that b the prob. and sorry ChrisC i dont know much about cars thats why what i could see wrong with car i wrote it in the post
