water pressure! desperate advice needed
my dream Zed is very rapidly becoming a nightmare!
first time a used it i got a water leak :(
fixed it :hyper:
used it again
water leak from pin hole in metal pipe :(
fixed it :hyper:
used it today
water leak from drivers side at the bottom!!!!!! :mad:
is it possible that the water pressure is to high and the radiator cap is not working
getting a bit p!ssed now
Billing just round the corner
any advice or help greatly apprietiated
cheers
the std water temp gauge is crap
it moves to the middle and stays there
how are you ment to know if its over heating
Its possible, I would spend some money and replace hoses cap flush the system etc, maybe even a new water pump as these cars run hot and rely on a good cooling system.
Rad caps are known to be a problem!!!
I hope this is cheap fix for you!
Make sure it is Nissan Oem as a lot of the patent ones are the wrong PSI!
