according to the bible
Runout - 0.056-0.127mm
Endplay - 0.013 - 0.096
in other words, not much!
ahh! so you should be able to feel it then?
No! if you can you gona have to change them soon so don't bother fitting them IMHO!
I hear there's a pair of Greddy turbo's going cheap at SE after a big engine build they were working on exploded ;) :D
how cheap is cheap? im looking to up these next
*****x!! lol!! you bunch of jesters!! :P
Jesters LOL the word :xxx: springs to mind:D
PMSL :D
I thought you should be able to wiggle it a bit "up and down" but not really "in and out"... where "a bit" is not very much anyway but enough to be able to feel it.
(By up and down I mean across the axis, and in and out is along the direction of the axis of rotation.)
Cos it doesn't actually spin on the bearings, it spins on a solidy-liquidy oil layer under pressure which sits between the bearings and the race? So no oil pressure, you'll get a bit of play.
Either way yours sound fooked as discussed yesterday :(
LOL!! after that technical description there should now be no doubt at all!! :D
Word of the day: Thixotropic! :tongue:
So now you felt some in good condition,did yours have too much play?;)
There was way too much play! and on closer inspection of one of mine the blades had started to go :shock:
