Help & Advice
My cars seams to be hitting a restricter about 7000 when I drive it hard,but when i take it up slowly this does not happen .Running with a JWT chip no boost jets ,done the pcv's in last 3 weeks but promblem was there before.
come guys any idea no this one ,been left with my pants round my ankles at the lights lately by some pi55 poor cars :xxx:
Are you sure you mean 7000rpm ! You shouldn't get beaten just because you can only got to 7000 instead of 7200 or 7500....
I was thinkin that!! 7000 rpm is at the top of the rev range anyway
Kirbz
Kirbz
will being to town later so I will give it boot down the east lancs and find out the the rpm's are
retarded ignition?
erm how about change gear at 7000rpm and then you won't have a problem ;)
What theres more than one gear on these cars :tongue:
it's happen twice today the revs are about 3500 and then it is like you hit a restricter so any ideas
Dave
my cars is a manual
i'm no expert at all but people talk about a faulty autobox ECU sometimes...
probably no use but i have a similar prob. but mine is at the end of 4th gear and about 5000rpm in top. feels like a speed restrictor but if i come off then back on it lets it go a bit further and so on. eventually it gets to the real limiter at about 7300rpm in top. is this right? Also, at 100mphor just over, my speedo stops reading and drops to zero. this makes the PAS revert to its lighter "town" setting and is quite a shock sometimes when cornering hard at these speeds. any ideas? cheers. si. :duffer:
I had the same limiter problem. Got it chipped problem solved.
