has my zed been chipped
How do i tell if my zed has been chipped?
if it has and the HKS EVC is disconnected will this cause problems
eg my code 34 at the moment (replacing plugs tomorrow)
if i disconnect the battery to reset the ECU
then reconnect and run the engine for 10-30 seconds then turn it off
will this then give me a diagnostics flash on the dash!
or is this an urban legend
if the new plugs dont solve it is a knock sensor bypass worth trying
or should i take it to some one to find out exactly what my zed has and get it all reconnected
any help apprietiated
3 weeks of Zed ownership - £££££££££££ :cry:
How to tell it's chipped:
Take ECU out of passenger footwell. (10mm socket reqd.) Open observing anti-static precautions. (Phillips screws at corners.)
http://www.ttzd.com/izcctech.html for plenty more detail!
Mines got a Nissan official recon unit in it and a weird white label with scrawlings on it on the EPROM, so I'm thinking... chipped!
http://rides.300zx.co.uk/rides/1982/chipped.jpg
If you're running higher boost and it HASN'T been chipped you'll likely have problems.
When you say the EVC is "disconnected" what do you mean? I don't think boost controllers usually frig any signals to/from the ECU - they just use them for reference - so you should be OK... except something must be controlling the wastegate solenoids, and if the EVC isn't you better make darn sure the ECU is.
Code 34 indicates a missing/bad signal from the det sensor harness more often than it indicates actual det - there's a bypass you can try to eliminate as a problem - search for "det sensor AND bypass AND resistor" or something similar...
Can you HEAR det?
If you know you've got a code 34 sounds like you already know how to get diags - I did hear a rumour you could do it by some method like you mention but doesn't seem very good for the car to me! So UL or not I wouldn't do it...
What's the background... have you bought a previously modded car that's been un-modded?
Code 34 will NOT be produced by Det - only by a bad connection/bad sender.
To see if its been chipped, you need to open up the ECU - or it may have a 'piggy back' computer hashed into the harness, typical example being HKS FCON...
ECU doesn't control the wastegates, only the stock boost solenoids - these should be disconnected for the EVC anyway so you'll be running on 7psi unless they reconnected them, in which case you'll STILL have 7psi due to the code 34 ;)
Yeah I didn't phrase that very well...
I meant weird things will happen if the ECU ISN'T connected to the stock solenoids AND the EVC isn't connected either!
Sorry, gotcha - all that will happen is he'll get 7psi, which he'll get anyway due to the code 34.....
car history-
got it from a member 3 weeks ago
he got it from an importer in june 2003
car was std so i was told
air filter had disintegrated
just changed plugs today
plugs were in terrible condition (back 2 really bad)
changed the oil
waiting for the road to dry to test it
car history-
changed the oil
Might be worth a look in the bigger intake pipes and the throttle bodies etc to see if you've got bits of air filter all round the system then :eek:
If the plugs were dead fair enough, I was just suggesting you might like to find out if you had det before you put another set of plugs in and kill those too, IYSWIM!
So where does the boost controller come into it? Have you added that?
boost controller was in the glove box
turning it on did nothing
but if i had a code 34 then i suppose it wont work anyway!
Thats the thing about boost controllers. You have to disconnect the stock boost solenoids for the controller to work properly, therefore removing the ECUs ability to put the car into safety boost. In other words, if the boost controller was fitted and setup, then yes you would get higher than 7psi....
Yeah. If you've got a boost controller cabled in, switch it on for sure. But, you won't get safety boost. I'd be inclined to turn the boost down on the controller to 7psi until you've got everything sorted and you're confident you understand what's going on (cos I certainly don't LOL)
I reckon you should fish around the vac lines down the side of the plenum, and work out...
a) If the stock solenoids are still connected (can't tell you where they are off the top of my head... try searching on here?)
and
b) Where your boost controller solenoids are (follow the electrickery, should be easy to spot because it won't look like the stock harness)
Doesn't really sound like your car was stock after all. ;)
The ecu will still think its in safety boost though so you will be in the knock maps - this will mean the ecu is advancing the ignition slightly for an extra margin of safety ;)
John Dixon could tell you more....
That will be retarding the ignition then Andy :rolleyes: :tongue:
Yep - I actually meant to put that - **** knows what happened :confused: Too much eagerness for the old lunchtime :duffer: I think :rolleyes:
tested the car today
running a lot better with new plugs
fitted 2 new coil packs instead of the worn ones
now running even better
finally fell like i'm getting somewhere
ps goes up to 7000rpm now
but didn't look at the boost gauge
blew away a renault clio V6( he was not happy)
:dance: ALL WORKING :dance:
replaced the two worn coil packs and bingo
everything is working
HKS EVC works 1bar :dance:
cheers to paulg :duffer: for great advice/help :bow:
:dance: :dance:
just need rear shockers now
No problem mate.
And we finaly know yes it is chipped but its a mystery chip :eek:
no stickers or anything probably fitted in Japan.
Paul
