poss ptu probs ????????
If I drive my car from cold all is well untill about 20mins into the drive the boost will cut to around 6psi if I switch the car off and let it stand for around 20mins then restart the car is fine untill it warms up again, does this sound like a ptu prob?? I have the standard series 1 unit fitted :rolleyes:
sounds more like a detonation/sensoe problem
didn't you repair your det sensor harness a while ago? if it throw up a code 34 it would indicate a problem in that harness or the sensor itself.
I have no diagnostic gear to check with, Ive seen there is a link to this check with out it I cant find it though! would the ecu not stay in this safety mode untill it was reset? I did find a break it the det wire I have resoldered that together its had a new sensor fitted too
Sounds like it's going into safety boost - an ECU diag will tell you why!
OR you've got a dicky temp sensor so once the car goes into warm running it gets hopelessly confused?
thanks I'll give it a try and see what it comes up with, I'll put money down it the most expensive and awkward part to replace
thanks I'll give it a try and see what it comes up with' date=' I'll put money down it the most expensive and awkward part to replace[/quote']
Or the cheapest and most impossible to replace det sensor! :(
