Which Clutch?
I think I need to replace my stock clutch before I look at upping the boost on my car, does anyone have any recommendations?
Can thoroughy recommend the RPS "street" for daily use on a midly uprated engine. It uses a new backplate with stronger springs and the standard friction plate. Feels almost like standard and doesn't slip. Got mine from Smithy.
RPS Street sounds like a good plan, what about the flywheel at the same time? Worth doing?
RPS Carbon-Carbon will do nicely :D;)
What's good for non silly money, bearing in mind I only want to go to about 300RWHP.
Hi mike, as you can see the ole RPS is pretty much up there mate, the sport version will do yer nicely and comes with everything you need supplied, as for Flywheels, yep skimming yer existing is reccomended or better still as a labour FREE mod (which ain't bleedin common) an after market lite weight flywheel will certainly improve acceleration fella, RPS billet being fully rebuildable for life or slightly cheaper model is the Jun flywheel, very good too, Have ALL 3 in stock at the mo, though that don't normally last long bud, throw in FREE SGP racing uprated pivot ball too. Mail me if yer like for upto date pricing and check me section in traders area.
cheers
smithy
