cruise controll
does anyone think it would be possible to take the cruise controll system off a auto Z and fit it to a manual Z without cruise or will it be a serious shitter of a job,
or does anyone want to come and do it for me in exchange for as many cups of mellow birds as they can drink biggrin.gif
Paul
I'm not sure about the Z cruise control equipment but on my old XJS the cruise control had things like a vacuum pump for the throttle to hold the speed and other mechcanical bits and pieces that would have been hard to retro-fit. If the Z's cruise is all electric then that may need alot of wiring changes! smile.gif
Trev
Trey is right..
The C.C. on the Z is ECU-based, and quite a bit of cabling, solenoids, handles, buttons and other bits and pieces are involved.
Also if you have a steeringwheel with airbag you need the C.C out of a Z with an airbag (or vice versa) otherwise you'll have to change the steering wheel as well.
The C.C on airbagged Z's is controlled by a small handle, while the C.C. on non-airbagged Z's is controlled by buttons on the steeringwheel
-Eric
There are companies that do specialise in installing aftermarket cruise control. I've seen adverts.
Try a search!
Tim
None of the aftermatket cruise control are supposed to work acceptably on a turbo car (different way to maintain speed)
I wanted to install a Cruise Control into my wife Subaru Legacy SuperStation Turbo (with the ADW & the rallye engine ;-)...turned out to be a nightmare....
So, if your Z is a NA....easy....if not...good luck
Henri
  • 1 month later...
Hi all,
I need a new cruise control actuator part for my Z (according to Nissan UK) !!
Does anyone know what it actually looks like ? Where is it located (if under the bonnet, where ?)
My car is a UK 1993 Manual TT.
Your help is appreciated.
Thanks.
Alesi ? nice drive last sunday (sorry couldent resist it)
