Slight oil leak
Engine oil dripping onto p/s pump.
Have had very good look on ramp - but can see nothing.
Anybody else had same problem.
Mark
Mark
I had an oil leak from my 300, oil was dripping onto the air cond pump at the other side of the engine, I thought it was the rocker covers but It ended up being the left hand cam seal (left hand as in looking from back to front). I could feel the oil when i put my hand down between the engine/fan and pushed my fingers in behind the plate that sits against the engine on the inside of the timing belt that the cam covers bolt onto, when i removed the belt/cam pulleys then the plate on the pass side, it is shaped so the oil doesnt go inside the cam box and contaminate the belt.
Cheers John Crisp
Thanks John - I`ll have a look
Allthough all cam seals were replaced a year ago.
Mark
Wow oki then, hopefully it aint the dreaded rocker cover...what a nightmare job that was...plenium off....ouch.
Cheers John
