Fitting Blitz Dual SBC Boost Controller?
Got one on order with Johnny da main man.
Are they easy to fit and will I need any extra bits to do the job?
I think Johnny said they usually only come with Jap instructions but he's trying to sort me out with UK ones...
Also got Blitz Boost and Water Temp gauges on order. Boost gauge sounds easy enough to fit but what about the water temp? Does it come with it's own sensor or use the existing one. If it has it's own sensor how/where does it fit?
I have a JWT ECU and their website states: Boost Increased to 12.5 PSI (13.5 PSI flash boost)
What is flash boost and does this mean I cannot go over 12.5 PSI on the Blitz Controller?
What is the safe maximum for the Z?
[This message has been edited by ChrisC (edited 29-08-2001).]
Go to the tech section on my website for a installation-guide of the Blitz-DSBC
(http://300zx-twinturbo.com)
I'm running 16 PSI (17PSI flash/peak/scramble/whatever) with my JWT-ECU and it's fine.
-Eric
Thanks Eric that's just what I needed!
Where can I get the T-Pieces from?
Is high pressure fuel hose OK/right size or should I be using something else?
Any hose that can withstand more then 3 bar is more then enough...so fuel-hose is fine.
You can get the T-pieces from the same shop you buy the fuel-hose from ;-)
..make sure the T-pieces fit the hose though !
-Eric
Searched everywhere for the T-Pieces!
Harry Halfords have 'em in their parts catalog but none in stock anywhere.
Eventually found a garden pond plumbing kit at B&Q!!
Got the bits but the controller hasn't arrived yet :-(
