Auto Transmission Diagnostic Port?
Has the ZX a diagnostic port for the auto transmission, if so can somebody tell me where it is located.
I have done the on board diagnostics and I am just getting constant flashing, I believe this indicates that the battery has been off, how many start-stop cycles does the car need to build up a history again.
1991 jap spec zx N/A with hold + power switch
Dont know if there is a specific port for the auto box, but there is capability to do a check on the autobox within consult, what it does I dont know as I have a manual, ask danny zat in the traders forum
it's probably flashing an error code:
All 10 flashes the same = No error codes detected.
1st flash longer than others = Revolution sensor is shorted or disconnected.
2nd flash longer than others = Speed sensor circuit is shorted or disconnected.
3rd flash longer than others = Throttle sensor circuit is shorted or disconnected.
4th flash longer than others = Shift solenoid "A" circuit is shorted or disconnected
5th flash longer than others = Shift solenoid "B" circuit is shorted or disconnected
6th flash longer than others = Overrun clutch solenoid circuit is shorted or disconnected
7th flash longer than others = Lock-up solenoid circuit is shorted or disconnected
8th flash longer than others = Fluid temperature sensor is disconnected or A/T control unit power source circuit is damaged.
9th flash longer than others = Engine revolution signal circuit is shorted or disconnected
10th flash longer than others = Line pressure solenoid circuit is shorted or disconnected
http://twinturbo.net/ttnettech/autodiag/autodiag.html
