As people may know I am up grading my car a little and I have the choice of better brakes or Xenon lights. Which should I go for?
What Mod Should I Get 29 members have voted
  1. 1. What Mod Should I Get
    • Larger Brakes
      22
    • Nissan Xenon Lights
      7
Yeh gotta be the brakes for me also. Will be getting details of some cracking 6 pots soon ;)
Eat more carrots, 300zx lights are not that bad,
after being in stu's car its gotta be brakes, its awesome!!
Brakes,If you go for the lights you will only smash them when you try to stop:D;)
Brakes:) ,looking back i should of done this first rather than other mods,been a few times when i thought"Fookin hell its not gonna stop in time"(plus one hairy moment when the handbrake was allso applied to stop the thing:D )When i get these GTR brakes on no more doubt if i can stop!:dance:
Tony
Are the GTR33 brakes a straight bolt on - I've heard that only certain wheels will bolt as std on front of zed due to original calipers being very big. Are the GTR33 brakes smaller in size?
ap racing expensive but very good 343mm with 6 pot kiss the windscreen job
Stopping definitely or seeing a bit more.....
Got to be stopping. :D
The problem with 6 pot is the pads tend to be huge and cost a lot. Plus the master cylinder may not be up to it.
Stuart
Brakes without a doubt.
You only have your lights on when its dark.......... you use your brakes all the time!
The only advantage with the HID's is you will be able to see what your crashing into:D :D :D
Brakes if you drive hard... and I'm sure you do. ;)
As someone else said you only use the lights in the dark... and how hard can you drive in the dark even if you bolted the floodlights from Hilton Park to the front. :) Plus it's now getting lighter not darker.
I'm quite impressed with the stock brakes considering the weight of the car but they do fade on B-roads - nearly made a new layby on Woodhead pass the other day!
Are uprated pads/disks better or worse in the wet?
