Looking at getting a boost gauge and just wondered if it's worth getting any other gauges at the same time cos I'm gonna get the pillar trim and need to know how many pods.
Vijay
I can strongly recommend an oil temperature guage.
(and maybe a better/clearer watertemp-gauge as well)
-Eric
The fitting of the gauge itself is a piece of cake, but it's the oil temp-sender that might be difficult to install.
I bought a gauge with a sender in the oil-drain plug, but wasn't too happy with the result..now I have soldered/welded the sender to the oilpan (oilpan is made of copper) and it works like a charm.
If you've got balls of steel you can also drill a small hole in the oilpan and install the sender that way.(and pray that there aren't any shavings on the inside of the pan)
-Eric
