ECU that'll work in a NA, TT with MT or AT?!!!
According to this advert, the ECU they're selling will work in a Zed that's TT, NA with a MT or AT gearbox. I'm not sure whether I believe that, what do you guys think? I always though that the ECU programs were different.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33597&item=2443444443
Unless there's some way of switching the ECU's configuration with dip switches. :confused:
Dunno about N/A against a TT but i very much doubt it, BUT a MT will not swap with AT but it will the other way around. There is something in there for auto boxes. I would avoid that deffo.
If you buy Car parts mart from WH Smith for 99p, company in there advertise ECU'S checked etc for 300's, they will also try and match your ECU model.
smithy
From the fact that they call it a "turbine" and thay they "are not sure of its exact spec", I would say dont touch it with a barge pole. I am not sure from AT/MT, but I am sure that a turbo eprom is different from that on an NA
The TT would run right off the end of the load scales on a NA map I would think (can't chack because I don't have any BINS at work).
