Where's the best place to mount the solenoid for the Boost controller. I know it should be within three feet of the turbo's but I have also seen people mount it over by the hicas set-up. Where have you guys mounted yours ?
Stu stick it on the right handside of the batt between the inner wing nice and cold over there;)
Stu,
Just to be different mine is situated on top of the left hand strut as you look at the engine bay
Ryan
Thanks mate, I was going to put it here, as per lymons site but I think that where you suggest would be a better option as I won't have the hoses running all along the front.
ofcourse you are free to put the solenoid where ever you want, but you want to keep the hoses to the solenoid as short as possible and of similar length to both left and right wastegate.
Installing the solenoid near the battery is not exactly ideal in this case.
ideal would be somewhere under the nosepanel.
-Eric
I put them under the nose cone then thread the hoses through the gaps down the side of the rad.
There's plenty of room if you've got an aftermarket filter, if not you can get it on front of the standard air box, in the bumper.
