strange ECU, help required
YO,
i took my ECU out today to have a look at chipping it,
only to find i cant find the chip i need to replace :s
and i seem to be missing the daughter board.
member_zoom.asp?member_id=1091464&member_name=lee-man&img_id=3423254
any idead where the chip is i need to replace on this thing?
and why im missing the daughter board.
nothing to do with hicas is it?
cos my car is a '95 and so has the electronic hicas, not hydraulic.
any ideas dudes?
cheers
Lee, it's the later OBD-II 16 bit ECU you have. Not too many people seem to know too much about it.
I have a contact in japan who can get it done for you, or JWT do it.
I believe it replaces a surface mount EPROM with a daughter board and a 40pin 27C1024.
oh bloody great
is it a good ecu lol
so now instead of a 20 quid chip or what ever, il prob have to pay 400 quid now cos its bit rarer.
oh joy.
would i have to de-solder one of the 40 pin chips then :S
do u know what the daughter board does and why i aint got one?
is it just an extension of the mother board and they managed to fit it all on the mother board on the later ones?
cheers dude!
You're right about the daughter board, guess they just integrated it into some of the other bits.
You could look into doing it yourself, look for an EPROM number on one of the chips, and RS do converter sockets to change it to a DIP, it might all fit in there but I'd imagine soldering it would be a nightmare without all the proper iron heads and things.
You'd still have to get hold of a tuned ROM for it though.
This disscussion has popped up a few times on the Aus300ZX forum of late.
I also have a j-spec zed which uses the same ecu as per the one in the pic and is also identical as the pic JWT have on their site and it is listed as a 16bit ecu.
This ECU was used from 10/94 - 01/97. (j-spec fast confirmed)
I believe this ECU is an OBD11 ECU
http://groups.msn.com/ZfromJapan/partsforsale.msnw?action=ShowPhoto&PhotoID=119
Andrew
thanks man
thanks for just ruining all my plans to chip my car
frikkin 800$???
i was planning on 20squid lol
oh man
donations very welcome ;)
cheers for the info dude, i may have to save a little first :S
Heh, heh........when you start to poke about with the
electronics on a Zed, it's gonna cost.
Sheesh! 300 horses ought to be enough.
Have you fitted an induction kit?
Let the thing breathe
Improved the brakes?
(You could take Bugatti's attitude to a customer
who complained about the brakes....
"M'sieur, I make my cars to go, not to stop.")
You might want to check if the ECU's are pin compatible - just a thought but you might be able to swap it for an old one
ive got zees zorst and apexi induction kit.
dump valves
thats bout it performance wise lol
yeah they are wise words lol
i would like to get the brembo brakes but cant afford it at mo lol
any ideas as to what else i can do thats cheap and effective lol
cheers dudes
