Engine bay hoses
Anyone know what size hoses I need to replace all the vacuum hoses, fuel hoses, etc, in the engine bay?
Mike,fuel is 8mm,smallest size is 4mm for the vacume taken from balance bar etc,am sure the other vacume size is 6mm,will check this for you today.
Ok Mike this is what I used;)
3mm bore for washer tube and balance bar
5mm bore for SBC
8mm braided fuel lines,you must get the teflon lines that take pressure,mine will cope with 700+psi,stock only runs at 40 psi I think;)
4mm and 6mm samco will fit,however IMHO the 3 and 5mm bore fits better;)
