Ignition coil Relay
Anyone know where the ignition coil relay is located ?
hmm ok I guess I'll have to find out the hard way.
When in doubt, google. Stick ignition coil relay Z32 in the search box and the first doc which comes up says:
Find a source of 12V IGN power. Nissan's source of power for all the ignition coils comes from the ignition coil relay located in the relay/fuse box. It's located on the front driver side of the engine compartment. Next to this box there is a brown connector, a large gray/white connector and a gray connector. Disconnect the gray/white connector in figure (5.) and expose about 3/4" of wire from the thick black cable (6.).
google
Or even look at page EL 110 here http://300zx-twinturbo.com/cgi-bin/manual.cgi
HTH - Gio
its in the relay box in the engine bay, on the passanger side at the front. i take it out to immobilise the car has i havent got an alarm or immobiliser;)
